Recording from Sky+ using Smartlink - does it work?
Discussion in 'Sky Digital TV Forum' started by CharlesElliott, Sep 27, 2004.
  1. CharlesElliott
    CharlesElliott
    Mar 18, 2002
    55
    I have Sky+ and a Sony SLE-SL740 video (I also have a Sony DX32-100 TV but I don't think that's relevant).
    I'd like to use the Sky+/Sony Smartlink feature when recording stored Sky+ programs off onto tape but i can't get the video to recognise any Smartlink signal from the Sky+ box. Has anyone got this working?
    I currently have the following connections:
    Sky+ VCR Scart <=> Video Scart 1
    Sky+ TV Scart <=> TV
    Everything seems to work well (switching to video signal when video is on, recording from Sky+) - it's just that Smartlink doesn't work!#
    Cheers,
    Charles
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Yes, I have the equivalent of Smartlink working fine. Check that the scart input on the VCR is the correct one for Smartlink to work - it's usually only one of the two that's compatible.
  3. CharlesElliott
    CharlesElliott
    Mar 18, 2002
    55
    Thanks, but it definitely doesn't work on either of the two video SCARTS. Any other suggestions?
  4. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Thinking further, we might be mixing terms here. Smartlink, and the other companies' alternatives, are protocols for communication between TVs and recording devices.
    What is needed for your set-up is communication between a satellite box and a VCR.
    My VCR has a 'satellite-link' facility, where the VCR stays in a standby mode until it receives the trigger signal from the Sky+, 'telling' it to start recording. Recording then stops at the end of the programme. This is separate from the Smartlink system. Sorry for the confusion.
