Recording from Sky+ to VCR
Discussion in 'Sky Digital TV Forum' started by JaneK, Mar 15, 2006.
  1. JaneK
    JaneK
    We've just had Sky+ installed, and it's all working perfectly except that we can't record programmes that we've recorded using Sky+ onto VCR.
    I think this problem is due to how the Sky+ box, TV and VCR are connected together. Can somebody tell me how they should be connected?
    I've seen another post on here which describes the connections in terms of AV1 and AV2, but our connections are labelled differently:
    TV: AV1 and AV2
    Sky+ box: TV Scart and VCR Scart
    VCR: VCR decoder and TV-RGB Composite
    Any help will be appreciated!
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Connect Sky+ TV scart to TV and VCR scart to VCR, what's the problem?
  3. RockStrongo
    RockStrongo
    Jan 11, 2005
    874
    28
    Newcastle
    +53
    I think the problem may be that they're all labelled differently.
    You need to connect a scart cable from the sky output to the video input. Looking at your labels I'd guess it should go from VCR scart on the skybox to VCR decoder.
    Good luck . . .
    Edit: Mind you - why would you want to record onto VCR?
  4. JaneK
    JaneK
    My OH wanted to tape a boxing match that he'd recorded, for someone who doesn't have Sky. ;)
  5. RockStrongo
    RockStrongo
    Jan 11, 2005
    874
    28
    Newcastle
    +53
    Fair enough . . .
    If all else fails you can try unplugging everything and wiring the sky cable and aerial into the skybox, run a scart from the output socket of the sky box into the VCR input socket and then a scart form the VCR output to the TV. You should then be able to play a Sky+ recording and press record on the VCR.
    Another thought - you also need to select the right channel on your VCR (Usually aux1 or 2 - sort of "below" channel 1).
    Once you've done it throw the VCR out ;)
