Recording From Sky + To Toshiba RDXS-32
Discussion in 'Blu-ray & DVD Players & Recorders' started by lurcher, Jan 12, 2005.
  1. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Read the threads re STB codes for above but cant find a code that allows channel changing on Pace Sky Plus unit.
    Want to be able to timer record to Tosh from Sky but the only way I can work out to achieve this is to leave the Sky unit on the required channel when timer programming the Tosh
    Is this the best I can do ?
  2. jdarushall
    jdarushall
    Don't think you will find them. I looked into this a while ago and the Sky+ box uses different codes to normal ones. This is why most questions like this go unanswered.
    The theory is that you can use the Sky+ box to record to a HD so why would you want to do this anyway.
    In practice do you trust the Sky+ box to record it properly and also pay Sky 10 quid extra for the box to do this.
    The only way I can see this is to use Sky+ to record as it should, which means paying the Sky+ fee and then when playing back from the sky+ box, record it as a live programme.
    Remember the programme on the Sky+ box is not compressed (?) and hence you should not lose any quality by doing what is effectvely two generation recordings.
    If you haven't got the Sky+ subscrition then your stuck with leaving the box on the right channel and recording :thumbsdow
  3. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Thanks for the reply , yeh its as I thought.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    As jdarushall says there is no way to get a Toshiba to control a Sky+ box. But to be honest with dual record now on Sky+ you are not really going to achieve anything extra anyway. You can't record two channels on Sky whilst and a third on the Toshiba (unless from the internal tuner!).
