Recording from Sat. on Panasonic DMR-E75v
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigbill, Nov 12, 2004.
  1. bigbill
    bigbill
    I am experiencing problems trying to record a satellite prog. on Panasonic DMR-E75V recorder. In the manual it says "first set up programmes using Video Plus." I have done this, however, at the set time for the particular prog. It only records what is on the TV screen at that time. Have I got it wrong? Is the recorder only supposed to do this?
    There is no problem recording two programmes simultaneously on VHS and DVD.
    Anyone able to help
  2. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    I can only think that when you set up the video plus code it is automatically trying to record a terrestrial station, as it would. You can still use videoplus for satellite but you need to make sure you change to the relevant input or extension for what the satellite is plugged into ie AV1, AV2, unless you do this already when I will have to pass on your question :)
    Regards
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Video plus is really a waste of time for recording from sattelite and very unreliable on analogue in my experience.
