Recording from Freeview
Discussion in 'Digital TV & Video Players & Recorders' started by Sapper Pete, Jul 6, 2005.
Tags:
  1. Sapper Pete
    Sapper Pete
    Jul 5, 2005
    19
    My setup is as follows:- Goodmans Analogue TV - VCR - DVD player - Freeview Box. All systems work OK through a 3 way scart control box.This is possibly a silly question,but is it possible to record Freeview channels to VCR ?
  2. JayCee
    JayCee
    Jan 20, 2004
    22,332
    Lanarkshire
    +2,328
    Not a silly question..........if you have a scart lead from the freeview box to the vcr set the vcr to it's "AV" or "EXT" input and you can then record whatever channel the freeview box is on.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,336
    Rainham Essex
    +2,433
    Does your Freeview box have 1 or 2 scart sockets?
    If only 1 then conect the FV box to VCR and then VCR (assuming this has 2 scart sockets) to TV or switch box.
    If 2 then connect TV scart to TV/switch box and the other scart (normally labelled as VCR) to the VCR.
    To record you need to set the VCR to record via the AV (ie scart) input. If you have 2 scarts sockets on the VCR then you need to make sure you select the correct one.
    Mark.
  4. Sapper Pete
    Sapper Pete
    Jul 5, 2005
    19
    JayCee and Mark - thanks for info. At last I have something to work on and keeping my fingers crossed !
