recording from digital input
Discussion in 'AV Receivers & Amplifiers' started by harris87, Dec 24, 2001.
  1. harris87
    harris87
    Mar 17, 2001
    35
    united kingdom
    i am considering purchasing a sony dolby digital/dts reciever shortly,but was wondering if it is possible to record music from a dvd,if it is connected to optical/co-axial digital input on the reciever,and record the sound to a minidisc player or other form of recording device..
    can anyone please clarify this for me?
  2. William
    William
    Sep 4, 2000
    60
    Shropshire
    I have a similar set up so may be able to help. You will be able to record from CDs using the digital input to the Minidisc player but this will not work with DVDs.
    Minidisc players have built in Serial Copy Protection (sorry I have forgotten the correct term for this) to control whether copies can be made etc. The source material eg CD or DVD can have Bits set which will allow or disallow copies being made. They can also determine if 2nd generation copies can be made. Unfortunately with DVDs it appears that the Copy Protection Bits are always set to prevent any copies, so it is not possible to make digital recordings on minidisc. This Serial Copy Protection mechanism only applies to the Digital Inputs on a Minidisc so you can still make analogue copies.
    Even if you were able to make direct digital recordings from a DVD to a minidisc player, you would only be able to record the PCM stream so could not make multichannel recordings (eg DD 5.1 or DTS). However the normal stereo recording can provide matrixed sound such as Pro Logic.
    I hope this helps.
    William
