Recording from a TV VCR to a Sony TRV33E
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by flash2, Jan 9, 2005.
  1. flash2
    flash2
    Please Help! has anyone on this forum been able to do this, I have read the manual provided and gone through all the options, but get a blank screen when I record?
    Has anyone else experienced this and been able to fix it.
    Many Thanks
    Flash
  2. Brian110507
    Brian110507
    Are you using the scart adapter which came with your camera to do this - if yes this is your problem - the adapter supplied with digital camcorders is wired IN to the VCR - you need to pop down to your nearest Maplin and get a dedicate scart OUT adapter or one which you can switch in and out.
  3. flash2
    flash2
    Thanks. will give it a go...
    Flash
