Recording Freeview
Discussion in 'Freeview & YouView' started by Phil66, Jan 16, 2008.
  1. Phil66
    Phil66
    Oct 16, 2004
    15
    Hello all,
    I have just bought a Toshiba Ragza XF355D TV. How do I record Freeview channels? I have a Sony DVD recorder (RDR GX7) a Sony Sky box and a One For All wireless sender.
    Phil
  2. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    In most cases on TVs with a built-in Freeview tuner the signal will be outputted from one of the SCART sockets.
    Refer to your user manual for details.
    Of course you can only record the Freeview channel you're watching or set the TV for a timed recording
    If your DVD recorder doesn't already have Freeview IMHO it's easier and certainly more convenient to connect to a separate Freeview box
    EDIT>>>>>>
    Just had a quick look at a .pdf user manual for the Regza series and I can't see your question dealt with directly.
    However, this screenshot shows that AV1 and AV2 can be configured to output DTV (Digital TV)
