Recording Freeview on HDD
Discussion in 'Blu-ray & DVD Players & Recorders' started by nish75, Nov 6, 2005.
  1. nish75
    nish75
    My TV has freeview but my DVD recorder does not.
    Is it possible to do some looping to record freeview on my recorder?
    Thanks in advance.
  2. anna the dub
    anna the dub
    Dec 14, 2004
    274
    +12
    Depends on your tv. I have a jvc idtv and this particular model allows you to designate the 2nd scart socket to output the freeview signal. I have this connected to my Pioneer recorder via a scart to 3 phono (the av in on my Pioneer is taken up by sky) and it works perfectly. Check your tv's manual.
  3. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    It's likely that one of TV's scart inputs (usually AV2) also outputs the TV's digital tuner so that you can record Freeview onto DVD/VHS.
  4. sjw
    sjw
    Feb 19, 2003
    1,900
    63
    +215
    Likewise on my Sony it allows you to select what is transmitted through AV3.
    But only AV1 and 2 are RGB. :(
  5. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    I can only seam to make recordings while my tv is on, when off the recorded picture rolls out of sync every 5 secs, I have only tested this on my Thompson DTH7000, might have to replace it if I can't sort this, I sould really try my old vcr to see if it has the same problem.
  6. sjw
    sjw
    Feb 19, 2003
    1,900
    63
    +215
    To record Freeview from your TV, usually it either has to be on or in standby. Not off..
  7. nish75
    nish75
    Thanks for all your suggestions.
    Since my DVD recorder is old, I think I will get another one with Freeview.
    The quality of the recording may also be better.
  8. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    On my LCD I think it only has "standby" unless you unplug it at the wall.
  9. ross5247
    ross5247
    Not sure if this is relevant here but this question came up about the Sammi LE26R41BD - here is the post and answer:
    POST
    Cheers :)
  10. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Recording from TV freeview tuner is probably more trouble than its worth. Buy a £30 freeview STB and connect that to the recorder. This will leave you able to watch one freeview channel and record a different channel at the same time.
  11. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    It was for timeshifting, £30 after just spending a grand ROTFL.
