Recording episodes????
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jonniejames, Mar 16, 2006.
  1. jonniejames
    jonniejames
    Is it possible to set the sky plus box to record every episode of a tv program? For example the rest of the desperate housewife series on wednesdays at 10pm?
  2. Lee
    Lee
    Mar 2, 2006
    5,858
    +2,737
    Yes. If you go into the planner after you have set it to record, highlight it and it should give you the option to series link it with the green button.
    lee
  3. jonniejames
    jonniejames
    cheers lee!!!
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Yes, like the earlier post suggested this is what the whole idea of the Series Link feature is about.
  5. John
    John
    Dec 13, 2002
    11,635
    +3,304
    But is only works if the "channel" implement it properly . In my experience CH4 and its associated channels are not the best , and the link feature is frequently lost
    Good luck
    John
