Recording DVD-R to HDD on E-85?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cuewoz1, May 22, 2004.
  1. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    Just wondering if this is posible? I was reading Home cinema choice and they seem to say yo only can record from a DVD Ram to HDD? and not -R.
    Can some one with one confirm this please.
  2. RBJTech
    RBJTech
    May 7, 2004
    583
    43
    Kent, England
    +101
    This is incorrect - having just done it on my E85 (from a DVD-R) it is indeed possible to dub to the HDD. However, this is in real time and re-encoding mode only (ie XP,SP etc) - no high speed dub can be done. Perhaps with a DVD-RAM this can be done high speed (and without re-encoding) but having never needed to use one I don't know the answer to this one ...
    Of course being a DVD-R any CPRM, MV and CSS had been removed so don't expect this to work on an original commercial DVD ...
    I'm also positive that DVD-RAM disks keep the CPRM (copy of a copy control) signal so this is why they may be able to be copied at high speed (and the original then removed from the DVD-RAM)...
