Recording DVD -R and playing back on a PC
Discussion in 'Blu-ray & DVD Players & Recorders' started by Elliston, Jul 27, 2004.
  1. Elliston
    Elliston
    I have a Panasonic DMR E50 and I am trying to play DVD -R discs recorded on this machine back on Power DVD5 on a PC...but it doesn't work. Am I chasing a dead duck or is there a fix ? Any ideas anyone ?
  2. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    There should be no problem but you will have to "finalise" the disc first.
  3. Elliston
    Elliston
    Tried that but it won't play....
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,252
    +2,820
    What DVD drive do you have? Does it recognise the DVD in My computer?
  5. Elliston
    Elliston
    I have a DVD drive (Liteon DVD ROM LTD163D) but I had problems getting Power DVD5 to read the drive (It initially kept coming up with no disc in drive E) I managed to get it to work eventually and have installed rpcde2.exe to bypass region coding plus DVD genie. Ordinary DVD's play. Could these progs be causing problems ? Would I be better off using some other means of bypassing region coding etc ? Perhaps I should start from scratch ?
  6. nwgarratt
    nwgarratt
    May 5, 2002
    26,252
    +2,820
    The region thing shouldn't matter as the DVD-R's should have no region afaik.
    Anyway, I use AnyDVD to make my R2 drive act like a region free one. A free program called DVD43 will do the same. No other software is needed and PowerDVD should just play the DVD.
    You could try another DVD player program such as Media Player Classic (freeware).
  7. Elliston
    Elliston
    OK thanks for the tips I'll try it and report back....
  8. Kevo
    Kevo
    Aug 23, 2001
    5,354
    Manchester
    +144
    Try a firmware update, that worked for my Pioneer DVD Rom
  9. Elliston
    Elliston
    :lease: After trying various suggestions this is the message I get when I try to play a DVD-R recorded on my panasonic machine when I try to play it on Power DVD 5.
    "DVD-Video playback graph building failed"
    Any ideas as to why this won't work ?
  10. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    check the manual of your recorder, that it has a DVD compatability mode like the Toshiba, it maybe recording a hybrid mpeg 2 format which is unplayable
