recording dvd for USA
Discussion in 'Blu-ray & DVD Players & Recorders' started by annew, Jun 30, 2004.
  1. annew
    annew
    I want to record vhs tapes to dvds that can be played in the USA.
    Is there a dvd recorder that has multi region recording?
    I am a newbie to all this , so could you please keep it simple!!!!
    Annew
  2. chard
    chard
    Dec 12, 2002
    398
    16
    sorry mate I don't know the answer, just echoing your question as I would like to know how to send a DVD to a friend in the States for them to play back either on a telly or computer....
  3. JH4
    JH4
    May 6, 2003
    2,429
    83
    +271
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    ....and just to amplify what's in that thread and the other place it links to:
    The issue you face is not about DVD regions. Typiclly a "home made" DVD will not have any region restriction on it.
    The issue is about video standard. Your European VHS material will be in the PAL signal format - 625 lines, 25fps etc. Your US counterpart will probably only be able to playback NTSC video (525 lines, 30fps). So to make a usable DVD you need to convert your PAL video signal to NTSC. That's what the other thread is about.
    Standards conversion is something which can be done using encoding software on a PC as described. I don't know of any table-top DVD recorder that has this built in - it would be an expensive addition.
