Recording directly from a camcorder to a firewire hard disk
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by scook17, Apr 24, 2003.
  1. scook17
    scook17
    How do I record directly from my camcorder to a firewire hard disk? I noticed Maxtor do a 250GB firewire hard disk. This seems much quicker than recording to Mini-DV and then having to play this back into the computer at x1 speed. Just record directly to a hard disk and then connect the hard disk to the PC for the editing.
    Is there a device which I can buy which will allow me to do this?
    Kind Regards,
    Shane Cook.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    I am only guessing here but I would think that this would not be possible.
    A firewire disk is still a PC device. The PC controls all the i/o to the device.
    Your best bet would be a camcorder to laptop to ieee1394 disk (or just to the laptops internal disk).
    Mark.
  3. scook17
    scook17
    Mark,
    I figured that one out, but it then requires you to spend a grand on a laptop, just to control a hard disk. It's not easy to carry around a laptop, plugged into the camera all the time, plus most laptops only have a single firewire connector. No, I was after a bit more of a portable solution, which you can easily put directly into the computer. It's a shame the camcorders don't contain the software to drive a hard disk directly, because you could then just mount the hard disk unit onto the bottom of the camera.
    Kind Regards,
    Shane Cook.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    The only other option would perhaps be to use a DVD-R/RAM camcorder. This would allow you to copy the video from the DVD to PC at a higher speed, but these cams do have lots of limitations.
    Mark.
