Recording Digital Channels from Sharp 32GD1e
Discussion in 'LCD & LED LCD TVs Forum' started by J__T, Mar 23, 2005.
Tags:
  1. J__T
    J__T
    I have a Sharp 32GD1E I have hooked it up to my video recorder, but haowever i hook it up i seem unable to get the digital channels to appear on the recorder, i only get the standard 1 - 5. Does anyone have one of these or know any info if it is possible to record the digital channels from the built in freeview decoder from the TV.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    You just bought an expensive screen so go and buy a Freeview PVR
  3. Hikikomori
    Hikikomori
    Nov 27, 2002
    69
    11
    West Midlands
    :nono: Cheaky! But then again, I kinda agree :rotfl:
    Anyway, I've got a GD1 myself. I don't watch that much TV on it tbh, but I have got an old VCR connected to it... Connect your VCR's In/Out scart to scart #2, set your VCR to the relevant input and there you go. To record while the LCD's in standby make sure you enable standby recording (has to be set every time you want to do standby recording :rolleyes: ).
    Oh yeah, and welcome to the forums :)
  4. J__T
    J__T
    Thanks Martin for your help, i dont know what i would have done without that valuable piece of info
  5. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Unless you have a VCR that can record digital channels (I don't know of any), the only way of recording digital channels is via the SCART socket - the analogue channels that are on the VCR will be recorded using the VCR's own tuner. But having one digital tuner will mean that you can only watch the same digital channel that you are recording. This use is not unique to Sharp, it is how i-DTV's work in general. The solution to watching one digital channel and recording another is a second digital tuner. Either a standalone freeview box plugged into the recorder or as Martin says, a digital PVR.
