Recording audio-only
Discussion in 'Blu-ray & DVD Players & Recorders' started by liteswap, Jun 8, 2005.
  1. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    I have a Toshiba RD-XS32 about a year old now, and I've been very happy with it. However, I've not been able to persuade it to record audio-only -- eg radio from my AVR300. Any thoughts on how to make that happen?
    Thanks.
  2. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    Can't really help on what you want, however I have recorded onto DVD several freeview stations (ie Kerrang) and then if you have a pc extract the audio into whatever format you want - this is certainly one way.
    Regards
  3. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I don't have the XS32, but I guess you can use the front panel audio-in sockets. As the machine may want an accompanying video signal, you'll have to get either a composite or s-video feed in also. Any source would do as you'll be ignoring the video. It may be worth a try without the video signal if you haven't done so already.
    I have downloads of the manuals - try page 37 of the Operations manual. You should be able to get a composite video feed from a TV scart and then you'd use a scart to RCA phono jacks converter lead. Make sure it's wired FROM scart TO phono so the correct scart pins are connected/switched. See
    http://www.maplin.co.uk/Module.aspx?ModuleNo=28102&doy=8m6 or
    http://www.maplin.co.uk/Module.aspx?ModuleNo=1041&doy=8m6
  4. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    Thanks -- I'll take a look at those possibilities.
