Recording a program from the start
Discussion in 'Satellite TV, Sky TV & FreeSat' started by gers1978, Sep 12, 2007.
  1. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    Just read this line on another thread:
    "How do you think you are able to record a programme from the start when you press record half way through"
    Is that true?
    If so, I take it it will only work if you've been *watching* the program from that start as well?
  2. Clatter
    Clatter
    Dec 11, 2002
    224
    +15
    It only works if you have instant replay turned on, or are using live pause to view.
  3. Techno
    Techno
    Nov 20, 2003
    312
    Yep, effectively you have to have been on that channel.
  4. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    And it will only start recording from whatever your buffer is set to. If it is set to 30 minutes, it cannot record from the start of a movie that started 40 minutes ago, even if you have been watching from the start. It will only record the previous 30 minutes from the point when you pressed the record key.
