Recording a DVD soundtrack onto portable MD player via optical cable?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by thebigboss, Mar 2, 2003.
  1. thebigboss
    thebigboss
    I've tried recording the audio from a dvd onto my MD via a optical cable but it wont record. I've set the digital output to PCM and it still wont record. Is the copy protection on the MD being used?
    Any ideas ppl.
    P.S. Is it worth upgrading the free optical cable I got with my Sony MDR909 which I use to record from my Sony DVP-NS700.
    I was looking at the QED OM Optical Cable £24.99. Would I really notice much difference?
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    This thread may be of interest you :
    http://forum.hifichoice.co.uk/viewtopic.php?t=4213
    Im not sure your personal MD recorder will have a 48Khz sample rate convertor in it, if its a MD personal I would use the cable supplied, cables only really make a difference on full size MD decks.
    HTHs
  3. thebigboss
    thebigboss
    Brilliant, thanks for that. It seems it is the MD's copyright protection system as it as a built in sample converter.
    many thanks
