Recording 2 programs in a row using EXT LINK feature on Panasonic E85 and Sky
Discussion in 'Blu-ray & DVD Players & Recorders' started by patroller2, May 20, 2005.
  1. patroller2
    patroller2
    Hi was wondering if anyone else had this problem? I have a panny e85 and it is connected to my sky box via video scart. EXT LINK works fine when recording 2 separate programs from the personal planner that when one ends and the next one starts there is a gap in between (i.e.one ends at 17:30 and the next starts at 17:35 etc). The problem I have is when one starts directly after the other (i.e. first program ends at 17:30 next one starts at 17:30) esp on same channel, as the first program ends and the next one starts the recorded screen goes blank you can hear the sound but you can't see a picture. Has anyone else had this trouble?? :lease:
  2. Richard Solomon
    Richard Solomon
    Jan 15, 2007
    5
    Yes, I have the same problem with my e85 - have you discovered a fix for it?
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,860
    +6,689
    Are you using the Sky VCR socket to connect to the EX85 and mode 1 Ext link.... or the Sky TV scart socket and mode 2 External link?
  4. Fast Jon
    Fast Jon
    Dec 8, 2004
    260
    +10
    I haven't been able to get ExtLink recordings to work either; I get the audio but no video. It looks like the Sky box is switching itself out of RGB as soon as it wakes up.
  5. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    I have the same issue with my EX-75. The most reliable way to record is to leave the Sky box on and set the timer on EX-75 to record from AV3 (or whatever). However, this only works for recording from a single channel.
  6. Richard Solomon
    Richard Solomon
    Jan 15, 2007
    5
    I am using Sky VCR socket and Ext link 1
  7. Richard Solomon
    Richard Solomon
    Jan 15, 2007
    5
    Just to be clear - using ext link works very well and is a much quicker way to record from sky - it only gives a blank screen on consecutive programs, and this is very annoying
