Recorders with DIVX support.
Discussion in 'Blu-ray & DVD Players & Recorders' started by rheum, Nov 21, 2004.
  1. rheum
    rheum
    I found a few threads that touch on this subject, but no real answers. What I'm after is a DVD recorder that has good DIVX playback support (no HD). Now I've found this unit in Germany, but readily available until Dec and only in Germany, so would need to get it shipped:
    http://www.xoro.com/product/HSDR505.prod
    Also found this unit:
    http://www.elliondigital.com/DVR-530S.htm
    But can't confirm that it has DIVX support....it says "DIVX ready", but what does that mean.
    And one thread said that the Yamada recorders support DIVX playback. Can anyone confirm whether the Ellion supports DIVX playback or whether the Yamada recorders do?
  2. celeronmanuk
    celeronmanuk
    Sep 10, 2004
    15
  3. rheum
    rheum
    thanks for the reply...nice unit, but I didn't think that was a DVD recorder only a HDD recorder and DVD player. I checked on the Kiss website and I think eBuyer have it listed incorrectly.
  4. celeronmanuk
    celeronmanuk
    Sep 10, 2004
    15
    yes, i think you're right. It's not very clear.
    Very nice piece of kit though!
  5. tdale
    tdale
    I am guarded about DivX support, from incompatibility Ive read about. When Divx or XVid change versions, you may find that some files wont play. I find it just as easy to watch via TV Out, and if I wnat a keeper, I just record on the DVD Recorder (where my TV Out plays to). hatb way the long reencoding on the PC is not a problem, no audio-sync issues, very easy. Best way to deal with PC files IMHO
  6. rheum
    rheum
    Yeah know what you mean...mind you've I've got a DreamX DVD/DIVX player at the moment and it has not has any problems playing any DIVX/XVID film I've tried.
    I got a response from Yamada tech support saying, not sure why don't you give it a go!! would do if I had a recorder to try it on :smoke:
    No reponse back from Ellion, but good response from Xoro...can't see why someone doesn't distribute Xoro kit in the UK??
    Anyone on here with a Yamada DVD recorder tried and had success watching DIVX films on their unit??
  7. rheum
    rheum
    For reference, got a response back from Yamada and they do not support DIVX. The Ellion only supports some versions of DIVX but possibly not XVID.
