Recorder with Component In
Discussion in 'Blu-ray & DVD Players & Recorders' started by fiendish, May 28, 2005.
  1. fiendish
    fiendish
    Hi all,
    I know it's been discontinued but I've been searching high and low for the Sony RDR-HX900 (because of it's compent inputs), with no luck. I'm also having little joy in finding an equivalent recorder with anything other than the usual composite/video/rgb inputs. Does anyone know of any available or upcoming DVD recorder with component in?
    Cheers,
    Ollie
  2. fiendish
    fiendish
    apologies for the bumpage but anyone got any ideas?
    Ollie :lease:
  3. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    I doubt that they will as there will be nothing to be gained from using component inputs from a HDD/DVD recording point of view. AFAIK only DVD uses component and you're unlikely to use it to record from DVD to DVD.
