I am confused about the list of channels you can watch while recording 2 others.
The other night, I was recording Channel 4 & Channel 5.
Both are LH (Low, Horiz)
I thought this would allow me to watch other channels on the same LNB setting.
(or even maybe anything, since both recordings could use the same LNB).
But all I could watch was Ch4, 5, 4+1, Film4, and the alternative BBC regions in the high 900s.
I can see no pattern to the list of available channels.
Why couldn't I watch BBC2,3,4, etc? Surely they are also on LH.
most odd....
It's not the band that's significant (assuming you have 2 cables) it's the transponder.
The rules are
Recording two channels on different transponders - you can watch (but not time shift) any channel on the same transponder as either tuner is recording.
Recording two channels on the same transponder - you can watch and time shift any other channel
In your example CH4 is on 10714H and CH5 is on 10773H
The other channels you could watch are
125 More4 +1............................ 10714
300 Film4............................... 10714
301 Film4 +1............................ 10714
974 Channel 4........................... 10714
102 BBC Two............................. 10773
106 BBC Three........................... 10773
107 BBC Four............................ 10773
600 CBBC................................ 10773
601 CBeebies............................ 10773
950 BBC 1 London........................ 10773
957 BBC 1 NI............................ 10773
