Record tv show with sony trv350
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by raulcjuarez, Apr 30, 2003.
  1. raulcjuarez
    raulcjuarez
    Apr 30, 2003
    10
    3
    I tried hooking up the av cables in the back of my tv to the camcroder and i couldnt get a picture on the lcd screen and couldnt record anything. Maybe im doing something wrong any help will be appreciated.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I am assuming that your camcorder does have its inputs enabled and that your cam was set to VCR mode!
    The AV sockets on a TV would normally only be inputs, therefore they would not output a signal to the camcorder.
    Try connecting to the AV sockets on a VCR, but check as not all the sockets on the VCR will be outputs although most VCRs sockets do both or will have both, but separate.
    Mark.
  3. raulcjuarez
    raulcjuarez
    Apr 30, 2003
    10
    3
    I connected my cam to the satellite receiver and i got video running onto my lcd screen but now it wont record. Will i have to buy a vcr and record from there, is that the only way?
