Record Pro Logic-sound on VCR?
Discussion in 'Digital TV & Video Players & Recorders' started by adlerberth, Aug 6, 2001.
Tags:
  1. adlerberth
    adlerberth
    If I record a movie from TV which is sent in Dolby Pro Logic to my stereo VCR, will the recording the be Dolby Pro Logic, or just stereo?<br />I mean, (new) video cassette rentals are recorded in Dolby Pro Logic, so it seems logical my own recordings will also be in this format.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,606
    Somewhere in South Yorkshire
    +6,147
    Short Answer: Pro Logic.
    There is nothing technically different between a Stereo signal and a ProLogic one. They are both, actually, just stereo signals.
    A prologic signal differs from a simple stereo one ONLY in its contents. A Prologic signal will contain audio components within the left and right channels which are specially designed (using different phasing) to be interpreted by a prologic decoder to give the required surround effects. More detail if you want it.
