Record players (78 speed???)
Discussion in 'Hi-Fi Stereo Systems & Separates' started by DDDavo, Nov 16, 2003.
  1. DDDavo
    DDDavo
    Does any one know where i can purchase a brand new record player that will play the standard 33, 45 speeds as well as 78.
    I'd like to buy one as a present for some one but i don't know where i can get one from. I am sure i have seen them before. It doesn't need any onboard speakers or anything else, just the record player as it would be connected to a hi-fi.
    Any ideas please?
    Thanks in advance
  2. overkill
    overkill
    Nov 6, 2003
    11,848
    Murkeyside
    +1,206
    The only one i know of is the Rega 78' player. Go here :- Rega.co.uk and head for the products link. The 78 player is first up under turntables.Then check out the list of dealers, find a local one, and order it as i doubt they are stock items.
    Hope this helps
    Overkill
