Record decks - vinyl
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Neil_F, Aug 7, 2002.
  1. Neil_F
    Neil_F
    I know this is not hi-tech but........
    I would like to copy some of my old vinyl onto tape. I have a mini-system with an aux input but it will not accept phono. I believe I would need some sort of pre-amp between the record deck and the mini-system. Am I correct about this and has anyone any suggestions?
    Thanks in advance
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    NAD-PP1 @ £40 or a Project Phono Box @ £40 is what you require sir, well if it is just for getting to a mini system. Both of these are in fact phono amplifiers which will increase the signal to an acceptable level for a typical Line Input on an amp like Aux.
