Chalklands
Established Member
Does anybody have any opinions on record cleaning machines? Do they work? Any recommendations (I don't want to spend loads)? Are they better than using cleaning fluid and a microfibre cloth?
Yes they work and yes they are better than using cleaning fluid and a cloth. If you don’t want to spend a lot look at Spinclean and Knosti ‘bath’ type cleaners.Does anybody have any opinions on record cleaning machines? Do they work? Any recommendations (I don't want to spend loads)? Are they better than using cleaning fluid and a microfibre cloth?
