Reconditioned Sky+ Boxes
Discussion in 'Sky Digital TV Forum' started by Brigadeer, Mar 16, 2003.
  1. Brigadeer
    Brigadeer
    Your views please:
    Should Sky be providing NEW Sky+ boxes instead of reconditioned boxes as replacements?
    If you have had a reconditioned box - how has it performed? How long has it lasted? Have you had several replacements?
    I will be interested in all comments about Sky+ performance.
    Thanks.
  2. MrFurious
    MrFurious
    Sep 9, 2000
    14,335
    Cardigan Wales
    +1,582
    I am on the free trial at the moment,the first box didnt work,the new box works fine until i do this,i go into the tv guide and say i scroll across to see whats on later and press i to see what its about,the sky+ turns itself off every time i try this and takes about a minute to come back on???strange:confused:
  3. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    A reconditioned box could be simply one of the early models that has had it's noisy hard drive replaced or it's main board replaced as it's not economical to repair a circuit board.
    The question should be under the law are you entitled to a brand new replacement or do you have to give the supplier a chance to repair the unit before it's replaced.
    This will be different depending if you are within the warranty period of course, inside of the warranty you are entitled to a brand new replacment within a reasonable period and after that the supplier can attempt a repair before providing a brand new replacment or refund. Outside of the warranty all you will get is a repair or more likely a refurbished unit from a previous customer.
    You could argue that a refurbished SKY+ from the original batch that had it's HD replaced performs better than the original spec SKY+.
  4. mostly
    mostly
    Dec 14, 2002
    50
    oswestry
    +4
    My sky+ box failed 2 days after I got it. They lumbered me with a refurb under the guise of being a new unit. Its taken me 2 months of phone calls & emails to finally get a brand new replacement :/
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    IIFK the reasonable period is 28 days, i.e. if an item goes wrong within 28 days you can demand a brand new replacement. After that you have to accept a repair if they can do it, otherwise a replacement or refund. I don't believe replacement has to be a new one after 28 days, but could be totally wrong. ;)
    StooMonster
