I need some advice on recommended video settings for the AVR X2300.
I noticed last night while playing on my PS5 that the image quality wasn't as clear/sharp on the AVR compared to being directly connected to the TV, I upped the enhancement setting on the AVR which improved it quite a bit but not at the quality I'm used to. So my question what setting do I use to allow my tv to process the video? Is it the HDMI pass through setting or the bypass setting in the HDMI output menu OR shall I leave it off?
My VIrgin V6 box is also 4k compatible and should I change the resolution on the box to 4k or let the AVR process the video?
When I use the apps on my samsung frame 4k tv, the quality is so clear and crisp but anything connected to the AVR not so.
