X Xantia Guest Sep 27, 2001 #1 Hi,<br />Which cable (gage, brand, model) do you recommend for two Energy Take 2 surround speakers, bearing in mind that each cable should be 36 feet (11 meter) long.<br />Thank you.
L Lowrider Guest Sep 27, 2001 #2 I replaced the original thin wire with Cable Talk 3.1 and gained 3 dbs on calibration, plus a much better sound. Almost 40 feet (12 meters).
A aqureshi Guest Oct 4, 2001 #5 hat is the difference between Normal & Biwire. What advantageous you get with Biwire. Cheers
L Lowrider Guest Oct 4, 2001 #6 This is a sensitive topic I wouldn´t bother with biwire, just get a reasonable cable...
