Recommended software for DVD +-R?
Discussion in 'Desktop & Laptop Computers Forum' started by nfordenfield, Jul 26, 2003.
  1. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    I have just taken the plunge and ordered a Pioneer 106 dvd+-r and as I have very little knowledge with backing up software/burning, what have people had sucess with that i could easily pick up?
  2. TEK
    TEK
    Depends what you want to backup really. I tend to only use Prassi Primo DVD these days but I don't believe the A06/106 is recognised on it so you'd have to use RecordNow with the latest PX Engine updates (same thing basically but updated)
    A lot of people still use Nero but I've never found it that great with my 104 and Panny LSD311 :(
    I'm not sure about +R but for -R you should stick with discs using a Ritek dye (G03 or G04) for best results IMHO. I've had great success with console backups and DVD-Video with these (mainly Traxdata) and have stopped buying the more expensive Verbatim that I used to swear by. I'd really advise you stay away from the real cheapies, especially Princo dyes which you find on many discs inlcuding some Datawrite/Datasafe... you gets what you pay for so check out the info on them before buying
    A good supplier for media is http://www.blankdiscshop.co.uk
  3. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    dvd2one is good for 1:1 backups. Sadly not every type of dvd is copyable.
  4. TEK
    TEK
    DVD2One is great as is Pinnacle Instant Copy. DVD Shrink is supposed to be quite good and is free but I haven't used it yet as there are sometimes still a few problems with the results, especially regarding lockups on the layer break
    Unless the original DVD-Video is a single layer (DVD5) which is very rare these days then it is not going to be a 1:1 backup as something has to either go or be downsampled. And you'll still need software to actually burn the backup
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    RecordNow (Very reliable good burning program)
