Recommended scart lead?
Discussion in 'Cables & Switches' started by simonio, Aug 26, 2005.
  1. simonio
    simonio
    Jul 7, 2005
    39
    Hi Guys
    With my new panny TX-32LXD500 on its way to me I thought Id better take a look at the connections to get the best possible picture. I have a standard thomson sky box via a scart lead. Ive amended the settings to RGB which I believe is step one. However, can anyone recommend a scart lead to get the best possible picture quality? Not sure of costs but Ive seen QED? ones at around £25 - will this do the job?
    Appreciate any advise you can give.
    Simon
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    Try the cables forum there'll be loads of info over there. Personall I've a couple of Supra FS scarts which I totally recommend.
  3. simonio
    simonio
    Jul 7, 2005
    39
    cheers for that, didnt even know there was a cables forum!
  4. loadsofleads
    loadsofleads
    All the top makes such as QED, Supra and Ixos etc should compliment your plasma well, have a look at the advertisers list on the forum and shop around. :thumbsup:
  5. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    I just picked up a couple of SCART cables from Homebase in their 10% off day for £4.49 each. Fully shielded and Very Good PQ, they also have a nice gripping scart plug that doesn't drop out easily. Try one of them before splashing out on a 'branded' cable. :thumbsup:
  6. beanman
    beanman
    QED AV2110 or Ixos XHT611 are stand our performers.
