Recommended online retailer for PC bits?
Discussion in 'Desktop & Laptop Computers Forum' started by Bert Coules, Apr 28, 2002.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
    Would anyone care to recommend an online retailer for PC components? I'm seriously thinking about putting together an entry-level HCPC and it would be good to know about a reliable supplier.
    Thanks in advance.
    Bert
    http://www.bertcoules.co.uk
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
  4. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Never used scann, but the other two I use regularly, both excellent.
    to add two more:
    www.ebuyer.com - usually very cheap.
    www.simply.co.uk
    Again, I use both regularly without any problems.
  5. Der_Pobman
    Der_Pobman
    I normally use:
    www.dabs.com
    I used to use Insight a lot too, partly because I lived in Canada and they operated there too. Anyway sometimes their prices are good, they used to give free delivery too, dont know what they do now.
    www.insight.com/uk
    regards
    Der Pobman
  6. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Same as JSW -
    www.overclockers.co.uk
    I've bought quite a few bits from them over the past year and their service is great. Prices are very good too, but you can get cheaper (www.ebuyer.com) but no-one's service comes close to overclockers.
  7. Der_Pobman
    Der_Pobman
    I had a bad experience with Overclockers.com ... Bought a CPU from them which was fine for 8 months (through the autumn/winter), and then started to overheat. I reported this to them and they went through the motions, of replacing the heatsink and fan, putting Arctic Silver on etc etc. This did not help and eventually the chip died, computer would not even POST. This CPU was now just over 12 months old, however despite the fact I reported the problem to them while the chip was well within guarantee they flatly refused to replace it. To this day I have a dead Duron sitting on my desk as a reminder of what a great company they can be :)
    However until this incident I had no trouble with them, have not shopped with them since though (this all happened Summer 2001).
    The chips replacement came from DABS and has been happily, and cooly, running without any problems.
    Regards
    Der Pobman
  8. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    +3
    I've had problems with Dabs. Never had an answer to emails and had to wait over an hour for tech support to answer a phone. I only buy from them when noone else sells what I'm after.
  9. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    I've dealt with all the suppliers mentioned so far. They all have their quirks and problems. However, for choice I use Scan. Novatech are OK as well but I can go and sit on their doorstep when I have a problem.
    I'm really not happy with Overclockers. Misdescription etc.
  10. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    I'm really not happy with Overclockers. Misdescription etc. Admitted by them (I have the e-mail) but not rectified.
  11. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,637
    UK.
    +3,132
    I often use ebuyer.com, and they're service is pretty good. The only thing to watch is when ordering out of stock items. They don't hold items while waiting for the out of stock item to come in, and then something else could go out of stock. Worst case scenario means you never get your stuff.
    Only order in stock items.
    Gary
  12. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Bert, only pain with Scan is that thie customer service is LEGENDARY (in a bad way). If you need to contact someone with a problem about an item, you might as well give up. (All in my experience, of course!).
    I'm going to put a PC together shortly, and was going to do a "step by step" thing, as I've noticed a few queries about the mechanics of putting PCs together, and thought it might be useful.
    For what it's worth, when I was pricing things up, I found ebuyer about the best value. I'm intending to get an Antec case from http://www.kustompcs.co.uk, though, as they are considered fairly quiet and they are well made (useful when building a PC - you don't want to be slicing your hands on poorly finished case metal - and a decent power supply is a good thing, particularly if you're using an AMD processor). Also noticed that Kustompcs do the OEM version of WinXP for around £60, which may be handy for you.
    If you'd like a copy of my E-L HCPC spreadsheet, give me a shout.
  13. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Agree Scan used to be like that. Contacting them was the problem. Once you managed to get in contact the problems are solved soon enough. They had a big revamp about six? months ago with more phone lines etc.
  14. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
    Richard, thanks for the offer but I don't have any spreadsheet software. I'll look out for your step-by-step guide with interest, though. What sort of overall budget are you working to?
    Bert
  15. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I'll PM you a list of items, but do remember that there's a minefield of software config to sort out, but I guess the guys and gals here can sort us both out.
  16. Shirker
    Shirker
    Oct 30, 2001
    54
    9
    Leeds
  17. Dominic
    Dominic
    Mar 2, 2001
    289
    Essex
    +6
    scan is good so long as what you buy doesnt
    1)spin
    2)heat up
    3)have any moving parts
    so that rules out most PC parts.. maybe i will by cables from them :)
    i built a system last year then 6months later 40GB of data went....into the ether... it took 4 weeks for a replacement HD, they wont ship a replacement till they have tested the faulty goods, which took 2 weeks for them to get as they "lost" it in the returns dept....
    still its cheap gear and so long as you dont get any problems with it youre ok.
    I have also bought from Special Reserve... not online although you can, but a local store were doing 52x CD drives for only a few quid more than the likes of scan, without the carriage its worth it.
    Especially when 3 weeks later a memorex CDR detonated in the drive and shattered into a million bits. The shop swapped it no problems and i could do it same day.. no hassle, if that had been scan it would have been at least 2 weeks with no CD ROM
    just be aware ... those prices are cheap cos the after sales service is non existant..
    off my soap box now
    cheers:clown:
  18. mps
    mps
    Oct 16, 2001
    1,629
    London
    +58
