Recommended CSA for speaker cables
Discussion in 'Cables & Switches' started by JayDub, Jun 10, 2005.
  1. JayDub
    JayDub
    Jun 6, 2005
    63
    +8
    Apologies for playing the noob here, but how critical is the cross sectional area of the speaker cable.
    My system is a hifi system where the longest cable run is 12 metres.
    From what I have seen, 1.5mm2 is the minimum I should be considering. (My current cable is Gale XL105 donated by RS, which I think has a CSA of 0.825 assuming a wire diameter of 0.1mm.)
    However most cable manufacturers state their 1.5mm2 cables are only suitable for minin and midi systems.
    What are peoples real world observations? Is 1.5mm2 OK or should I be going for at least 2.5mm2?
    Thanks for your help.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    In reality 1.5mm^2 is rated up to 16A so is more than adequate for hifi purposes. :)
