Recommended cable for surround speakers
Discussion in 'Cables & Switches' started by iclarke, Sep 22, 2004.
  1. iclarke
    iclarke
    Aug 28, 2003
    16
    3
    Any suggestions welcome, I'm going to need a fair amount of the stuff so nothing too expensive. I was thinking of QED Silver Anniversary as it seems to get good reviews ? The speakers will be KEF Eggs ...
    Many thanks
    Ian.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Try Twin and earth electrical before you go splashing out on QED. Terminate with good quality banana plugs or spades and save a few pounds. By far the easier solution. Or if you want something considerably better try Cat5 Network cable. A bit more time consuming but often with better results. There 's a lot of advice about the making of the above on this forum.
    HTH
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    I'd agree wholeheartedly with what Knightshade says, I don't think I've seen a comment from any one who has tried the twin and earth/Cat5 route which suggests they'd go back to buying things like silver anniversary. These homebrew solutions offer so much better value that it seems pointless.
