recommended Amps for 2x 1000W JBL Subs?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by danny-p, Jul 18, 2004.
  1. danny-p
    danny-p
    Any recommendations for the above would be welcome and any info on extra battery installations if required, and good conponent/tweeters so that the system isnt 99.9% bass with unhearable vocals :
    thanks in advance
    Elduderino :cool:
  2. Scott_Mac
    Scott_Mac
    Assume they are 15" models?
    Need a touch more info such as car type, music type, budget, enclosed box, ported, sealed....
  3. danny-p
    danny-p
    They are both 15" and budget is around £300 mark....Its on behalf of a friend, he,s about to purchase an w reg pug 206.
    He listens to hip hop/ rap music and is open to any recommendations regarding sealed/ ported boxes and any decent component speakers also.
  4. Scott_Mac
    Scott_Mac
    Its gonna be tricky with that budget if we are honest.... for that type of music (IMO) a large ported box would be best - he will need the thiele small parameters to work out the corredct box size, and be able to build one and tune it to a decent frequency.
    Would buying used be ok? Cos if so, we can make a fantastic system :)
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=4950&item=5709572386&rd=1
    Or http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=4950&item=5709855389&rd=1
    First is better! That should take care of the subs.... and his teeth :D
    (Fitting guide for front speakers here: http://www.gti-driver.tk/)
    Stunning speakers: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=18798&item=5710563619&rd=1&ssPageName=WDVW
    Amp for fronts:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=4950&item=5709395163&rd=1
    Obviously very difficult to guage what they will all sell for, but all top notch kit. He'll need to budget for cables (high current stuff!) and with that amount of power some serious dynamat sound deadening.
    Maybe a trailer too, as 2 x 15" ported enclosure subs in a boot of a 206 isn't going to leave much space for shopping in Sainsbury's!
  5. danny-p
    danny-p
    HA HA :laugh:
    Thanks a million for all your advice and hard work put in searching for links to all the goods!!!
    I'll see my mate tonight and i'll keep you posted on the installations/purchases as /when they take place.
    Just a last thing, will the single rockford amp power both the 15" subs?
    If so how do you wire them up as both speakers are 4-Ohm single V-coils.
    Would you bridge the output from the Amp, then daisy chain the subs or would you wire it un bridged to each sub as normal?
    Thanks again for everything!
    Danny
  6. Scott_Mac
    Scott_Mac
    Either of the Rockfords will power them... the top one will do it easily - one per channel - you could bridge and daisy chain, but 1100WRMS (Rockford watts being 30% higher than rated as usual) would be painful!
    The 4 channel amp, you would obviously bridge on each channel... i chose those for ease of install.
  7. danny-p
    danny-p
    Okay, thanks...Looks like the top link is the one.
    Danny
  8. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    A watt is exactly that - a unit of measurement. What makes this one different ?
  9. danny-p
    danny-p
    I,ve been told this by many ice sellers.
    They said my amp was outputting 20% more @ 14.4v than the manufacturers figures..
