recommended amplifier power for speakers
Discussion in 'Home Cinema Speakers' started by guyb, May 25, 2001.
  1. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Hi All
    Being a bit of a newbie I need some help with the recommended amplifier power and speakers. The amp I am getting (Denon AVR 3801) gives out 105 watts per channel. The speaker I am going to buy state –
    Fronts –
    Recommend amplifier power – Watts RMS 10-90, Recommend power handling – Watts Peak 120.
    Rears –
    Recommend amplifier power – Watts RMS 10-80, Recommend power handling – Watts Peak 120
    Are these speakers going to be OK for the Denon amp?
    Also what difference would there be if I used the following speaker specification for the fronts instead of the spec listed above for the fronts bearing in mind that the amp gives 105 watts per channel? Would I notice any difference?
    Fronts –
    Recommend amplifier power – Watts RMS 10-120, Recommend power handling – Watts Peak 180.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    First of all the wattage rating alone is no exact measure for compability between amp and speakers.
    In short I would not see a problem using the speakers you named with the Denon, in fact it is easier to damage a speaker with a low powered amp than one which is too powerful (so called 'clipping').
    The recommendation range of xx-yy Watt by the manufacturer is of course a good guide, but if the amp is a little bit more powerfull I won't consider this as a problem.
    I mean surely you would not match those speakers with a 300Watt power amp, but as long as you stay resonable close it should be fine.
    When you hear distortion just turn the volume a bit down to avoid damage to amp (unlikely since it usually is fitted with a proteciton circuit) or speakers.
    Study the impedance (Ohm) and sensitivity (dB) of the speakers to figure if they represent a high load to the amp. The higher both figures the less load to the amp.
    [ 25-05-2001: Message edited by: Reiner ]
