Recommendations - Subwoofer Cable
Discussion in 'Subwoofers' started by WBC, Aug 11, 2003.
  1. WBC
    WBC
    Guys,
    For some reason the cable to my sub is knackered. I have just got a new amp, plugged my kit in & the the sub just sat and buzzed!!!!
    At first I thought it might have been the new amp but by testing it with an interconnect that comes with the amp (the standard phono/video lead) the sub worked fine.
    On that basis can anyone recommend a half descent interconnect, I don't want to pay anymore than about £30.
    I was looking at these, any opinions???
    http://www.hifibitz.co.uk/Warehouse/details.asp?ProductID=IXOXFA01300
    http://www.hifibitz.co.uk/Warehouse/details.asp?ProductID=IXOXHW406300
    http://www.hifibitz.co.uk/Warehouse/details.asp?ProductID=QEDPSW300
    Stace :D
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I use a £15 Ixos cable and it works just fine
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    I'm with Ian on this one - basic Ixos cable does a mighty fine job (i tried an expensive(ish) QED cable & couldn't tell any difference)
  5. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
  6. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Ditto. Works well with my CHT-15.
  7. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +135
    www.scorpioncables.com if u fancy a custom built one :) I use it with my Gallo sub.. very well built cable!
    Matt
  8. tan1415
    tan1415
    If anyone is buying a SVS sub. They have a great deal with Bettercables. A great porice for the silverserpents by better cable.
