Recommendations of Sub for my system please
Discussion in 'Subwoofers' started by acehole008, Aug 20, 2005.
  1. acehole008
    acehole008
    May 23, 2005
    46
    :lease:
    System:
    Receiver: Sony STR-DB830
    Screen: Panasonic PLasma:ST 42- PW4
    Sub: Paradigm PS1000 (130W)
    Fronts: KEF Q35.2 floorstanders
    Rears: KEF Q:compact
    Centre KEF Q 80C
    Am thinking of replacing my sub for a new one. Considering KEF PSW2500 to fit in with my current system. It is a fairly large room - 4.5m x 7m. Only reason I am replacing the Paradigm is it is too large and ugly for the front room (according to the missus) - hence the KEF in a nice appple finish to match the rest of my speaker set-up. Also considering the REL Quake but am concerned it may be to small for the room - or should I go up to the PSW3500? please advise.
  2. MACKY
    MACKY
    The kef psw 2500 could be ideal, im not sure with your amp but you could try the Kef 2500, and you want more base then have one at the front of the room and one at the back which may cost around an extra £100 as to Kef 3500 though you will end up with 500wtts as to 300wtts.... see what the missus says..(just ideas)...Macky.
  3. RSD123
    RSD123
    You could check out the new Paradigm seismic series which take up about a foot at all sides.
  4. chris
    chris
    Nov 20, 2000
    1,216
    romney marsh, kent, uk
    +28
    I dont think you will find any improvement with the 2500 over the pw1000, apart from looking better, infact IMO i think you will find it not as good as the 1000.
    I would say give the 3500 a home demo.
    It will look better and is possible a step up from the ps1000.
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    What sort of budget are you working on here?? Colour/finnish constraints??
  6. JorisFRST
    JorisFRST
    I love my PSW3000
    I'm fairly new to the scene, so not sure how it compares to others ?
