Recommendations needed for 2 channel amp
Discussion in 'AV Receivers & Amplifiers' started by AshF, Apr 30, 2003.
  1. AshF
    AshF
    Jul 1, 2001
    23
    Hi all,
    Can anyone recommend a 2 channel integrated amp suitable to drive a pair of Aegis Evo 1s (100 watts, 89 dB, 8 ohms)? Preferably I like it to be able to take the digital out from my Tag pre amp. Looking to spend about £200 to £350 on it.
    Many thanks,
    Ash.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    In that price range ... look at Rotel RA-01 and RA-02 (same amps but RA-02 has remote control), NAD C350 and C370, Arcam A75+ and possibly stretch to things like the Roksan Kandy and the "coming soon" Arcam A80 - oh and anything else your dealer has in stock.
    The RA-01 / RA-02 are generally reguarded as the "best" of the 250-250 bunch ... but many people prefer the sound of the others. Really in that price range there is no "best" option, but several recomended.
    Also take a look at what you can pick up second hand.
    Vikki
  3. mudan
    mudan
    Nov 26, 2001
    226
    Solihull
    +18
    I'm selling a NAD C370 in the classified sections for £300 ono.
