Recommendations for Scart Splitters
Discussion in 'Cables & Switches' started by CatManDo, Dec 13, 2004.
  1. CatManDo
    CatManDo
    Nov 5, 2003
    1,753
    South Yorks
    +242
    I have only one RGB socket on my TV and would like to connect both Sky & DVD to it (DVD currently connected to AV2 which aint RGB).
    What would you guys recommend out of the following:
    http://www.argos.co.uk/webapp/wcs/s...talogId=2501&productId=108277&clickfrom=image
    2
    http://www.argos.co.uk/webapp/wcs/s...talogId=2501&productId=103441&clickfrom=image
    3
    http://www.argos.co.uk/webapp/wcs/s...talogId=2501&productId=107064&clickfrom=image
    Opinions will be gratefully received.
    Am I likely to lose any quality when using any of the above as opposed to a direct connection to my TV RGB Scart?
    TIA
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Obviously the 29.99 job is going to be the best because you won't have to keep jumping out of your chair all the time to switch over. Will it deteriorate the picture ? Who knows, but if it does, take it back for a refund :smashin:
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  4. CatManDo
    CatManDo
    Nov 5, 2003
    1,753
    South Yorks
    +242
    Think I am gonna go for option 3.......would love the £50 suggestion though!
    The only prob is I am gonna how to use the TV sound for the PS2.
    Setup as follows:
    DVD to TV (DVD connected to amp)
    Sky to TV (Sky connected to amp)
    Xbox to Sky (Xbox connected to amp)
    I can't think of another way to do this, no spare inputs on the amp!
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,275
    The Borders
    +2,572
    CatManDo
    The Zektor HDS4 Component Video + Digital Audio switchers will do everything you require (apart from retaining auto aspect ratio switching if you want to switch analogue audio) without trashing your picture quality.
    Unfortunately there's an additional zero in the SRP over your option A or B – see http://www.zektor.com/hds42/index.htm
    Best regards
    Joe
  6. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
  7. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    get one of them one-for-all auto scart switching units
  8. CatManDo
    CatManDo
    Nov 5, 2003
    1,753
    South Yorks
    +242
    cheers will check theses out.
    Mr Cat thanks for the offer but I need more than two inputs
  9. CatManDo
    CatManDo
    Nov 5, 2003
    1,753
    South Yorks
    +242
  10. CatManDo
    CatManDo
    Nov 5, 2003
    1,753
    South Yorks
    +242
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I would order and see if it doesnt work with RGB send it back as it is clearly stated too, no idea on quality tho mate sorry
