Recommendations for Receiver & Speakers for Newbie
Discussion in 'Home Cinema Speakers' started by Jedster, Dec 15, 2004.
  1. Jedster
    Jedster
    Aug 4, 2003
    12
    Hampshire
    I'm a real newbie at the home cinema thing and was hoping to get some recommendations from anyone on what speakers and what receiver based on the following:
    I have an 18ft by 18ft room, I don't want to spend tooo much money, I guess around £1200 tops, (which having typed that does seem like a lot). What would be a good setup for both CD's and DVD ?
    I've looked at KEF Egg speakers and they seem to be well rated but will they manage with the size of my room?
    Any help will be much appreciated as I can't seem to arrive at a definitive answer and need to strike while the missus is still being accomodating to the idea ;)
    Many thanks
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,501
    London
    +995
    Does the £1200 budget include speakers & amp together, or just speakers?
    If it is both then I recently bought the Kef Qseries (Q4; Q6c;Q-compacts; PSW-2500 subwoofer) & Yamaha DSP-AX750SE amp for £1190 from Hi Spek.
    The Q series are much better than the 'eggs' and the 5005's but the only downside is that they're not a sub/sat system if floor space is at a premium. However, the Q4s are very discrete and even the wife likes them in dark apple :smashin:
  3. Jedster
    Jedster
    Aug 4, 2003
    12
    Hampshire
    They are nice looking speakers indeed, hopefully sound just as good as well, thanks for the recommends. Is the Yamaha amp a fairly staple favourite on this forum ?
  4. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Ohhh yes, thoroughly satisfied with my 750 - it's a great amp once set up right. Just ot muddy the waters I'll recommend the Mordaunt Short Avant range I've got - well happy with them.
    Have a look at the following thread for more advice to a man in a very similar situation:
    http://www.avforums.com/forums/showthread.php?t=171017
    Welcome to the forums and happy hunting! Two golden rules:
    Listen before you buy and
    Never listen to anything you can't afford :D .
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,501
    London
    +995
    Very sound advice :smashin: I still curse the day I heard the Quad L series :(
  6. Jedster
    Jedster
    Aug 4, 2003
    12
    Hampshire
    All good advice, but I'll tell you what, the choice and difference in opinions is astounding!!
    What about the Castle CC3's are these any good, seem to have a good write up...
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,501
    London
    +995
    The Castle compacts are probably the best sub/sats for the £1k mark, but the problem is that this would only leave you £200 for an amp!
  8. Jedster
    Jedster
    Aug 4, 2003
    12
    Hampshire
    Ha Ha, yep that could be a problem!! However as luck would have it the wife is allowing me to creep the budget up a bit...well a fair bit actually...which is kinda changing my way of thinking.
    How does a Pioneer VSA-AX5i Amp with Castle CC3's sound ? Is the amp too good for the speakers ???
