Recommendations for banana plugs.
scubadoo
Hello,
I've just fitted my Nexxia speaker wall plates and now i need to choose some banana plugs. I've never used them before so advice would be appreciated.
Cable is Audioquest Slip 16/2.
Is it worth spending more on QED screwloc or Audioquest Suregrip 100 over the Fisual Easy fix?
It's been a long time in the works so can't wait to finally get the cinema up and running!
Dave
rorton
Ive had some great results with these
I like the idea of the single centre pin that makes the connection, the other type seem to go slack after a while i find.
I didn't use the plastic covers that came with them, i used heat shrink instead
D
Deleted member 24354
The Fisual banana plugs (Amazon £12 for 10 plugs) are as good as anybody elses. You can spend a lot of money but as long as the basic build quality is good, then they will all pretty much do a similar job (no matter what the marketing material says).
scubadoo
Thanks, that's what I went with in the end. They seem really good quality at a reasonable price and I had no problems with any of them. I used the straight ones in the amp and wall plates and the 90 degree version for the back of the amp.
