Recommendations for a new beefy PSU
Discussion in 'Computer Components' started by owain_thomas, May 20, 2004.
  1. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    I think I need a new PSU, my current PC doesn't seem too happy about starting up atm. It might have something to do with the 6 HDs, overclocked athlon 2500+, 1 dvd writer, 1 cd writer and zalman fan controller its trying to power :zonked:
    Can anyone recommend a reasonably priced but not to loud PSU which can cope with this. If its a compromise between quality and noise I'd go with the noisier but better PSU (I can always mod it) as I don't think the Q-Tec one I have now is quite the 550w it's rated at ;)
    Owain
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,277
    Manchester
    +762
    Your're right about the Q-TEC. Their 550W is based on peak ratings (which are only valid for a few milliseconds). The max ratings make it more like a 350W PSU.
    Enermax have a good name, also some of the Antec ones.
    Chris Muriel, Manchester.
  3. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    I've been using a Zalman ZM400A-APF @ 400w which replaced a Q-tec 550w.
    Rob
  4. Kramer
    Kramer
    I agree with Chris. You can't really go wrong with anything from Antec or Enermax but there are plenty of choices available now.
    I'd definitely recommend dumping the QTec :zonked:
  5. Big Jim
    Big Jim
    I would recommend the the Tagan TG480, it is very well built and comes out well in the comparative review below against a Zalman:
    http://www.bit-tech.net/review/299/
    Quiet, powerful, well built, and much cheaper than a lot of better known brands...
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    agreed. cant beat the tagan's right now
