Recommendations for £10-£15 scart cables?
Discussion in 'Cables & Switches' started by Kronenbourg, Jun 28, 2005.
  1. Kronenbourg
    Kronenbourg
    Jul 8, 2003
    626
    46
    Surrey
    +118
    Anyone got any suggestions for makes and sources of scart cables in the £10-£15 category? Having just picked up a new LCD screen I am looking to upgrade my cabling a bit, or will the ones for that kind of price not be worth the effort of changing and if so how much should I be looking to spend?
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    http://www.tvcables.co.uk/
    This would be a good place to look for a start. Thor cables seem good. About £20 or so for a very well made cable. It's probably not worth spending much more. Others may tell you different but unless you've got money to burn there's probably not a lot of point in spending more.
    Another place to try is John Lewis. Own rebranded cable (It's Blue - Afraid I can't remember the make....) about £12 for 1m is also very good.
    HTH
  3. chriskenny
    chriskenny
    I purchased the QED 2110 cable which is excellent!! Have a look around bought mine off e-bay for around £16.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Try and find the Philex "Home Cinema" scart lead. It's an absolute bargain and I found loads in Robert Dyas for only about £7. :)
  5. DrunkenDuck
    DrunkenDuck
    Ref the Philex "home Cinema" cable
    B&Q are selling these off as clearance at the moment and are up at around £4.50
    Is this cable ok for RGB signal ?
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    This cable is excellent for RGB signal.
    It's basically the same as the Thor cable but the control leads (video switching, widescreen switching, +5V etc) aren't shielded as well as the signal carriers. It also has a far more practical metal plug. :)
  7. cabstar
    cabstar
    Mar 28, 2005
    1,026
    38
    Grimsby
    +11
    I use the ones that Homebase sell for £5.99 they are blue cable & fully wired. They also have gold plated metal scart plugs with posiclick so they do not come lose. I have found this to be more important than cable quality as scarts are notorious for coming unplugged. They also do these in half metre lengths which is godsend for av racks.
    I have compared these against QED & could see hardly any difference what so ever. I have also seen the ones in B & Q & didn't think the build quality was as good as the ones from Homebase.
    Hope this helps.
    Regards
    Gary
