recommendations <£250
Discussion in 'Home Cinema Buying & Building' started by horsegun, Aug 10, 2005.
  1. horsegun
    horsegun
    Aug 10, 2005
    69
    Bath
    Afternoon,
    Looking to buy an all in one system for around the £200 mark, but will go up to £250 if needed. The system has to have tall speakers, not the little ones that come with most systems. The reason for this is my good lady says so, something to do with looks. I don't really understand. Anyway, any help would be terrific.
  2. lisbonlegend
    lisbonlegend
    ive went for the jvc ths-66 because of the tallboy speakers just waiting on delivery £250 from sound and vision.I will let you know what its like once set up
  3. horsegun
    horsegun
    Aug 10, 2005
    69
    Bath
    That would be great thanks.
    Do you mind if I ask why you went for the jvc ths-66 over the JVC TH-S9?
  4. lisbonlegend
    lisbonlegend
    just thought it looked that little more stylish and i liked the large centre speaker as its getting wall mounted under plasma
