Recommendation required for 2 VGA monitors for CCTV use
spaceman763
I've been asked by a family member to buy two CCTV monitors for his office. Nothing fancy as only a VGA connection is required. Requirements are to buy the best looking monitor for under £100 each and must be wall mountable.
So far the Samsung SM933SN over on eBuyer for £92.99 has caught my eye.
Is this as good as I can get or should I be looking at something else?
Regards
eyepete
Depending on the make and model of the CCTV camera(s) you might be able to get hold of some software that allows you to view the cameras on a PC/laptop instead of buying a dedicated CCTV monitor.
Alternatively, why not hook up the cameras to a DVR or NVR - that way you'll also get remote access to the cameras so you can look in on the office no matter where you are.
Just a thought or two to add extra functionality.
Pete
