Recommendation Required: Digital Coaxial + Optical
Discussion in 'Home Cinema Buying & Building' started by tezzer, Nov 30, 2004.
  1. tezzer
    tezzer
    May 29, 2004
    25
    3
    +3
    Can anyone recommend an all in one surround sound system with both Digital Coaxial and Digital Optical (TOSLINK) inputs?
    Need a new box so I can hook up both my PC (Coaxial) and Sky Box (Toslink).
    Budget: c. £500
    Many thanks
    Terry
  2. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Denon 500.
  3. tezzer
    tezzer
    May 29, 2004
    25
    3
    +3
    thanks! looks great! have purchased.
    Tezzer
  4. Leporello
    Leporello
    :smashin:
    I'm thinking of buying the very same system for similar reasons. Please tell us how your setting up goes and how it works. :smashin:
