Abs77
I am looking for some advice/inspiration on setting a home cinema set up on a budget.
My room is 3 x 9 m with ceiling height of 2.5m.
I am looking to buy a used AVR for about £250 (Yamaha or Arcam) and pair it with a decent speaker system.
It will be used only for movies or TV. I do not need 4K or music streaming abilities.
With regards speakers I would be happy to start with 2.1 system or 4.1 system foregoing the centre channel for the moment. The screen is 122 inch diagonal and I am hoping a decent R/L speaker should suffice. So to start with I would need a sub + front R/L speakers +/- wall mounted satellites for rear surround (Like KEF101 or similar).
I am hoping to spend £500 or less for speakers. Probably be looking to buy used or even open box etc.
any recommendations would be highly appreciated.
A
A
