Question Recommendation for cheap projector
Discussion in 'Projectors, Screens & Video Processors' started by fozt, Sep 26, 2017.
  1. fozt
    fozt
    Sep 26, 2017
    4
    4
    UK
    Hi all,
    I am after advice on a cheap projector.
    I am looking for a projector that is around £200-£300. The projector will be used in the garden at night only, and it will be brought back inside when it is not in use. The projector will not be used frequently, thinking more of having friends over to watch football and the occasional film.
    Any recommendations on where to start, please?
    Thanks,
    Foz
  2. Vila
    Vila
    Aug 5, 2002
    1,553
    2
    116
    +783
    Given your limited budget had you thought through a solution for sound and for a screen?
  3. fozt
    fozt
    Sep 26, 2017
    4
    4
    UK
    Hi Vila,
    Good point, I hadn't actually considered that - But I do I have some speakers that I can use for this setup. Also this will just be projected on to a white wall - I know not the best, but it will be OK for what I'd like to use this for.
    Thanks,
    Foz
  4. Vila
    Vila
    Aug 5, 2002
    1,553
    2
    116
    +783
    Have a look through the classified on here - your budget should be enough for a second hand 1080p DLP optoma projector
  5. fozt
    fozt
    Sep 26, 2017
    4
    4
    UK
    I forgot to mention that this is a gift - So I would rather buy new if possible.
  6. Vila
    Vila
    Aug 5, 2002
    1,553
    2
    116
    +783
    Unfortunately theres not really anything I can recommend New at that budget new - I think you might get a cheaper optoma in a sale at richer sounds for closer to £500 but £300 will only get badly made projectors you see on eBay /Amazon that are very dim.
  7. fido dido
    fido dido
    Jan 15, 2013
    118
    blackpool
    +5
    when amazon have a sale on the lg ph550 goes for just over £300, its got Bluetooth for the sound a built in 2 hour battery and wireless mirroring to your phone
  8. Vila
    Vila
    Aug 5, 2002
    1,553
    2
    116
    +783
    Cheap Battery operated led projectors are going to be very dim - ‘good’ led technology is considerably more expensive than the equivelent bulb based projectors
  9. fido dido
    fido dido
    Jan 15, 2013
    118
    blackpool
    +5
    its good enough for 80 inch screen from battery and 100 inch from the mains, very portable with instant start up and shut down, lg are getting pretty good at this just check the reviews
